Flywheel ???
Old Jan 17, 2002 | 05:24 AM
RS91's Avatar
Flywheel ???
On the flywheel, can't you just replace the teeth or the gears?
I remember replacing the gears of the flywheel on my 1980 Mustang. All you had to do was apply heat on the gears which goes around like a ring then pry it slowly. I was hoping that it would be the same with 3rd gen Camaro..
Thanks....
Old Jan 17, 2002 | 07:10 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes it is possible, on a flywheel but not on a flex plate.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
