88 gta low idle question and no power seats
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
I just went to start up my 383 sbc
it idled at 200 rpm and was barly going
I had a oil leak and had to shut off the car after 30 secs so now I have to wait till tomm sealer dry times
I think the distributor is way retarded making it idle low if I turn it clockwise to advance it
advancing it will bring it up even with ecu control
Right
and the power seats don't work
they always do
Right
they always do
Re: 88 gta low idle question and no power seats
Turning the dist clockwise retards the timing. Set it to about 8° BTDC with the timing connector unplugged; expect it to gain about 20° or so when plugged back in.
Power seats not working is probably because they're unplugged from the little junction block where they get power from, or their circuit breaker is tripped.
Engine: 383 built
I have no idea
black cloth seats with power lumbar
Engine: 383 built
I just checked every fuse in my box and there all good
I refuse to accept that they both stopped working st the same time is that possible
Possible, of course.
Likely, not as much.
Be REAL careful what you "refuse to accept". National events these days should be providing an object lesson in that, right before your eyes.
The fuse/breaker isn't in the fuse box. The seats don't get their power through that. They get it from the junction block up on the driver's side kick panel, kind of behind the hood release cable, near the firewall. Their feed wire is one of the red ones if memory serves. (there's pink and orange ones too if I'm not too misshapen)
Engine: 383 built
There is a ten amp fuse under the dtiverseat
mine was blown
and now it works again
thank God
mine was blown
thank God
Eric-86sc
Jul 26, 2014 07:15 AM
Firebat
Jan 27, 2006 11:38 PM
