1987 dash oil pressure gauge
Old Jul 25, 2021 | 01:37 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
The oil pressure "gauge" in the dash of my 1987 Camaro isn't working. It sits on the bottom. Occasionally it bounces around and sometimes reads right. I just put a 383 stroker in and know it has oil pressure because I have a autometer mechanical gauge hooked up under the hood.
I know the dash gauge isn't all that accurate, and I know there is good oil pressure, but it is still a bit worrying driving around and the gauge reads zero.
What parts should I look into to see if I can fix this. Loose connection in the dash?
I installed a brand new sender when I put the motor in. It did the same thing with the 305 up until I pulled the motor.
Old Jul 25, 2021 | 03:55 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
Re: 1987 dash oil pressure gauge
A bad wire connection on top
or maybe ground wire
Old Jul 25, 2021 | 10:21 PM
89fast5oh's Avatar
Car: 1987 Z28 IROC
Engine: 6.2L
I took the gauge cluster out, cleaned and tightened the contacts and put it back together. The gauge works now but is very jerky, it doesn't go up and down smooth but jumps up with rpm, sticks, let off gas and it jumps down, sticks, ect. Probably as good as it will get.
DANNY25SS
Sep 25, 2013 06:34 PM
91eagle
Aug 30, 2013 06:48 AM
JulieGTA
Sep 25, 2003 09:59 PM
SgtSkip
Apr 25, 2003 06:51 PM
