406 sbc need help picking a cam
Old Aug 9, 2021 | 06:50 PM
Underdog1968's Avatar
Ok here's what I have, scat crank,scat I beam rods, je srp 22 cc inverted dome, offset roller lifters crower (solid), my heads are 220cc 2.08 intakes, 7/16 studs, retainers an valves are titanium, the intake is a brodix hv, 74 cc combustion chambers, this is going in a 2000 trans am, 350 turbo 3500 stall with 373 gears in rear, it's gonna be pump gas street/strip. Need help picking a camshaft, I'm gonna buy new springs to match cam
Old Aug 9, 2021 | 08:15 PM
406 sbc build, cam recommendations
I have a 509 block, splayed main caps, all parts are new, scat crank, scat I beam rods, je srp 22cc inverted dome, heads have 220 runners, 2.08 intakes 160 exhaust, 7/16 studs, 1104 cc rockers, retainers an valves are titanium, 74cc combustion chamber, offset crower solid roller lifters, brodix hv intake close to same spec as super victor, the trans 350 turbo 3500 stall, 373 rear gears, need help with cam celection, this is a pump gas street strip deal, I'm a little concerned with the compression may be a tad low , what he opened was the heads I was gonna run had 68cc chambers the found these heads an there 74 you get the picture, any knowledge would be appreciated,......
