Rear end gut swap
Subscribe
Aug 9, 2021 | 11:55 PM
Ok. Original plan was swap my drum brakes onto my new housing. That won't work. Please ignore that thread till I learn how to delete it.
New idea. Can I take the guts of a 92 chicken and put them into the housing of a 87 Camaro. I don't care about the drum disc conversion. I just wanted 3.23 posi. Can't just swap the carrier because the spline count is different. (87 to 92) if I can do I need to reshim it or can I just set it up as it was from the factory?
Reply 0
Aug 10, 2021 | 07:20 AM
Re: Rear end gut swap
What is the current axle? A 1987 could have a Borg 9-bolt, which wouldn't be compatible with a 1992 version 10-bolt Saginaw.
Reply 0
Aug 10, 2021 | 07:21 AM
Quote: What is the current axle? A 1987 could have a Borg 9-bolt, which wouldn't be compatible with a 1992 version 10-bolt Saginaw.
Both are 10 bolts.
Reply 0
Subscribe
