Rear end swap from 89 iroc to 92 RS
Old Oct 16, 2008 | 12:59 AM
Z28XTC's Avatar
I have bought a rear end from a 89 Iroc complete with disc brakes LSD and 3.73s and I want to swap it into my 92 RS as it has none of these. Is there any articles available on doing this swap and is there anything I should know or need about this?
Old Oct 17, 2008 | 08:17 PM
tanager11's Avatar
Car: 91 Z28 Vert
Transmission: TKO
Axle/Gears: 3.55 10-bolt
Re: Rear end swap from 89 iroc to 92 RS
Should more or less be a straight re & re if its the same with respect to the brakes (disk to disk or drum to drum), if the brakes are different you will need to swap the proportioning valve.
Do yourself a favor and pickup one of those adapters you can afix to your floor jack to raise and lower the diff....I think summit sells them for $100 bucks or so, WELL worth it. I did one without that adapter, and I will never do it again that way. Not terribly difficult...just heavy and cumbersom.
Old Oct 26, 2008 | 04:34 AM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
i did this swap by myself and i posted up pictures and everything i went through. you can look up my thread i did or just ask me if you wanna. i did a posi 3.45 and disc swap well worth it i tell ya.
as a matter of fact my sig pic is when i underwent the swap. i just used jack stands under tha axle and the lift was bad ***. good luck.
Old Oct 26, 2008 | 10:16 PM
69442DREAMCAR's Avatar
I found a disc brake rearend in the upullit yard, was a 5 speed car, any idea what gears they came with?
Old Oct 27, 2008 | 01:33 AM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
what bolt pattern is it? 9 or 10?
Old Oct 30, 2008 | 10:19 AM
tonys91rs's Avatar
Car: 91 Camaro RS
Engine: 305 TPI conversion.
i replaced my drum rear on my 91 with a 10 bolt disc from an 85. i did not need the prop valve for the brakes. the e-brake hook up was a little different though. its easy to switch and be sure to really bleed the brakes.
Old Oct 30, 2008 | 10:45 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
It's not that you need a disk/disk prop valve, the drum prop valve will work with disk brakes. But you may want a disk/disk prop valve to get the most performance of the rear disk brakes.
hectre13
Dec 11, 2023 08:14 AM
IroczFan
Oct 6, 2015 10:13 AM
mizz0313
Aug 12, 2015 06:45 AM
BlackBoulder
Aug 11, 2015 11:15 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
