1989 Trans Am GTA - Trouble shooting power mirror
Old Sep 5, 2021 | 06:58 PM
AJ-T/A's Avatar
Car: 1989 Pontiac Trans Am GTA
Axle/Gears: 3.27 (GW6)
Hi, just bought a an 89 GTA, and the passenger side mirror only moves up and down. Looking for some trouble shooting advise. And can you buy a replacement motor if required?
thanks
A.J.
Old Sep 6, 2021 | 11:35 AM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: 1989 Trans Am GTA - Trouble shooting power mirror
When mine does that i just keep toggling the switch. It/they will eventually start working. My guess is the little motors seize due to infrequent use. Is only the passenger mirror moving side/side? You could probably find a replacement motor, but you'd have to open the housing to find the size.
Old Sep 6, 2021 | 05:31 PM
AJ-T/A's Avatar
Thanks, you are probably right... the car sat inside for two years... will try what you said
A.J.
WSX123
Sep 15, 2009 02:41 PM
PAFORM350
Jan 7, 2008 08:45 PM
