How high can you take a 305?
Car: 87 sport t top
How high in the rpm can you take the stock 305 bottom end. My heads can handle it. Or rather. How many times can I take it to 6500 before connecting rod leaves the block.
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: How high can you take a 305?
(Max piston speed / Stroke) * 6 = Max safe RPM.
https://www.musclecardiy.com/perform...mance-engines/
I probably wouldn't go higher than 6500rpm on a 305. Then again, if you do, it'll accelerate the progress towards not having a 305 so could be a win either way.
