88 gta fuel pump sending unit question
Old Oct 10, 2021 | 06:05 PM
bensbaby's Avatar
Car: 1988 GTA Trans am 1 owner since new
Engine: 383 built
Transmission: 1995 camaro t56 6 speed
Axle/Gears: 3.24 posi 9 bolt
I just installed a brand new fuel pump sending unit with a walbro 450lph fuel pump that I rigged up
When I was trying to get it in it seemed to take 2 times to get the float clocked down
now I know that now it's in working
The fuel gauge went from 1/8 down to 0 empty
and It ohmed the same as my gauge
should I just get some gas cans from the store and 20l at a time and watch the gauge go up
has any one ever fully installed the sending unit and relized that the float wanst clocked down where it was supposed to go
let me know
ty
Old Oct 12, 2021 | 06:58 AM
Johnny Gun's Avatar
Car: '88 GTA
Engine: 355 SBC, AFR 195 heads, Stealth Ram
Re: 88 gta fuel pump sending unit question
Mine is stuck at well above full. I think my problem is in the wiring somewhere because I've gone through two fuel pumps since it started doing this and I know they were both installed correctly.
Old Oct 12, 2021 | 10:27 AM
bensbaby's Avatar
Engine: 383 built
I bought a brand new sending unit no pump stainless steel one rock auto the gauge always worked there was a time it floated around alot and it was driverside carpet under seat
you pull the carpet back
there is a ground wire under it that corroded up
you clean it up. And problem solved
19875speed
May 29, 2020 09:10 AM
VinnyX40
Oct 16, 2009 11:13 PM
FireTurdWS626
Sep 18, 2007 05:23 PM
abrown89
Apr 16, 2007 10:54 PM
ttopformula88
Feb 1, 2007 04:37 PM
