What are the two Plugins on the Thermostat Housing Used For?
Old Nov 29, 2021 | 02:19 PM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
As seen in the attached photograph, what are they& purpose?
Old Nov 29, 2021 | 03:05 PM
vorteciroc's Avatar
Top Answer: 1
Re: What are the two Plugins on the Thermostat Housing Used For?
Those are Vacuum Ports that are switched Open/ Closed, depending on the Engine Coolant Temperature.
They were used for the Vacuum Advance of the Distributor... and for Emissions control devices.
Are you using a 70s Era Small-Block in a Third-Gen?
Old Nov 29, 2021 | 04:54 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
One on the left looks like the EFE valve, right...maybe for the air diverter valve.
Old Nov 30, 2021 | 10:15 AM
72buickgs's Avatar
Car: 1984 Trans AM
Stock 305 in an '84 Trans AM of a car that was built for the Canadian market - no ecm
Old Nov 30, 2021 | 11:01 AM
72buickgs's Avatar
Car: 1984 Trans AM
Why would u want to influence the vacuum advance? does it have to do with emissions?
Old Nov 30, 2021 | 12:29 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Yes, it's for emissions. Retard the timing during warm up to heat the the o2 sensor and catalytic converters faster. Modern cars still do this, but it's through the ECM.
juanmhiii
Jul 26, 2022 06:35 PM
Stev3n
Jun 16, 2020 11:28 PM
Stev3n
Jun 11, 2020 03:32 PM
Realmac4
LSX and LTX Parts
Feb 14, 2019 11:53 AM
