Temp gauge
Old Jan 2, 2022 | 09:38 PM
blaze2fury's Avatar
Temp gauge
Hey all, I have an 89 s10 blazer 4.3 and since it seems like the s10 forum is dead I need your guys help. My temp gauge reads 0 and won’t move. I grounded the wire and the temp gauge goes straight to the top. Which means the gauge works? So if the gauge works why isn’t it reading? I have changed the temp sensor as well. Thanks.
Old Jan 2, 2022 | 10:26 PM
1985_IROC's Avatar
Car: 1985 Iroc
Engine: LB9, V8 5.0L 305 TPI
Axle/Gears: G80, ?
Re: Temp gauge
Which temperature sensor did you change? There are two on my engine, one specifically for temp gauge located between #1 & #3 cylinders.
Old Jan 3, 2022 | 08:17 AM
blaze2fury's Avatar
Re: Temp gauge
I changed the one on the passenger side.
xx138xx
Oct 31, 2013 04:15 PM
IROCBandit
Feb 3, 2002 11:59 PM
