1983 5.0 knock?
Old Feb 18, 2022 | 02:53 PM
Okaywhatever's Avatar
Car: 1988 TransAm GTA, 1983 firebird SE
Engine: 350,305
Transmission: 700r4x2
Axle/Gears: 327
1983 5.0 knock?
I bought a 1983 firebird trans am 5.0 5 speed to use as a winter car next year. Car is a rot box, and not worth saving. I have a super clean 88gta with 60,000 miles as my summer car.
i noticed the other day it sounds like the car has a very quiet knock. Doesn’t matter if it’s warm or cold, although seems more consistent when it’s warm. Although sometimes the noise can’t be hear when the car is cold or warm. I’m at a loss. Cut the filter open and no metal. Tried 10w40, no change. And it’s only really audible at idle-1400.
has a Gm goodwrench engine. Any thoughts?
Old Feb 18, 2022 | 03:30 PM
jkris53406's Avatar
Car: 87 Formula, 91 Trans Am
Engine: 355 tpi, 305tpi
Transmission: 700r4, 700r4
Re: 1983 5.0 knock?
Are you sure it is a rod knock? Remove all the belts and try running it again. If the noise is gone, it could be a power steering pump or AC compressor.
Old Feb 18, 2022 | 04:09 PM
Engine: 350,305
Axle/Gears: 327
Re: 1983 5.0 knock?
Not sure if it’s a knock, the ac and air pump have been deleted. I’ll try removing the belts
Old Feb 20, 2022 | 12:34 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 1983 5.0 knock?
worn camshafts can make some funny noises at times-I'd just run it
Old Feb 20, 2022 | 04:33 PM
Engine: 350,305
Axle/Gears: 327
Re: 1983 5.0 knock?
That’s the plan.
Old Feb 20, 2022 | 05:49 PM
NoEmissions84TA's Avatar
Re: 1983 5.0 knock?
Add some Marvel Mystery Oil to the crankcase and run it.
Old Feb 24, 2022 | 03:08 PM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
Re: 1983 5.0 knock?
Try adjusting the valve lash?
antman89iroc
Jul 11, 2012 07:55 AM
comealive305
Aug 1, 2008 05:22 PM
