1986 Trans AM LG4 5.0L Carb - ODB1 Code 34 MAP Sensor Circuit Error (Signal Low)
Car: 1986 Trans AM
Engine: LG4-305-Edelbrock Intake/Q-Jet Carb
Transmission: Automatic
Greetings,
I need to smog my 1986 TA with LG4 305 Carbureted engine and I am getting ODB1 Code 34. Swapped out MAP Sensor, still getting error.
What are the next things to do to troubleshoot?
Let me know,
Thanks,
Ed
Let me know,
Thanks,
Ed
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: 1986 Trans AM LG4 5.0L Carb - ODB1 Code 34 MAP Sensor Circuit Error (Signal Low)
did you swap out the vac sensor of the baro sensor. the LG4 doesn't have a MAP.
vac line connected to vac sensor? baro sensor port opened to atmospheric?
