Code Help
Old Jul 17, 2003 | 11:58 PM
Louis7184's Avatar
Code Help
When i check out my codes that my ECM is throwing it comes up with code 33 and 34.
its a 1986 camaro w/ a 2.8
how can ut be giving me these codes
33. High voltage (low vacuum) at mass air flow sensor (or MAP sensor)
34. Low voltage (high vacuum) at mass air flow sensor (or MAP sensor)
just makes no sense
thanks
LOU
Old Jul 18, 2003 | 12:24 AM
85f-bird's Avatar
Car: 85' Firebird (Project), 92' RS
Engine: 2.8L, LS1
Transmission: 700R4, 4L60E
Axle/Gears: 3.42 Open , 10 Bolt (ukn)
could be trying to tell u that the actual MAF is bad, that or ur not getting any power to it....did u get a code 12 in conjunction with ur codes? if not, then ur ECM might be screwed and i wouldn't trust any code that it sent u.
Old Jul 18, 2003 | 12:36 AM
Louis7184's Avatar
sry also geta code 12
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
