do you mix your coolant before?
Old Jan 19, 2002 | 12:31 AM
JeffC1500TBI's Avatar
Just wondering if you mix the antifreeze in a bucket to do the 50/50 mix or if you put on container of antifreeze in the rad and then 1 of water and so on? does it matter?
Old Jan 19, 2002 | 05:34 AM
ede's Avatar
ede
i pour it in seperately, i use a small plastic bottle fill with antifreeze then one of water, keeps me 50/50 on the mix.
Old Jan 19, 2002 | 12:57 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
I usually mix it before.
I have an empty, 1 gal. windshield washer bottle that I marked at 1/8, 1/4, 1/2 and the top. I fill it up to one of the lines with water, then up the next one accordingly with antifreeze.
Like if I only want a quart of mixture, then I fill it to the 1/8 mark w/ water, then to 1/4 w/ antifeeze, etc. That's two 1/8 amounts of each, or correctly speaking, one 16oz. amount of each to make 32oz.
Then I just poor it in, not having to worry about it being the right mixture or not. Plus there's usually a little left over for topping it off after it cycles through hot-cold a few times.
I guess I've done it so many times, I got tired of trying to eyeball it while pouring it into the radiator. ( <----- One eye missing)
AJ
Old Jan 19, 2002 | 01:36 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
IMHO it doesn't matter.
With a new engine or a drain & flush or something I put in however much AF I'm going to use (usually 1 gallon, then anything else like Water Wetter or block sealer or whatever, then fill it the rest of the way with water. I get it as full as I can. Then I fill up the tank to a little past the "Full Hot" mark with water.
That gives about a 70/30 mix, and within a couple of heat/cool cycles even the overlflow tank has the AF mix in it.
When I add, I add water most of the time, then if it looks weak, I add AF. My cooling systems don't leak though so I rarely add anything after a fill.
Old Jan 19, 2002 | 03:57 PM
85 Berl's Avatar
I keep an empty antifreeze bottle and pour 1/2 of my new bottle into that, then fill them both the rest of the way with water. That way, I can keep a bottle of ready mix in the trunk.
Old Jan 19, 2002 | 05:45 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
Just remember that if you have flushed the engine with straight water, the block is still holding probably 1 gallon of the stuff. So if you pour in a 50/50 mix it will actually be a gallon weaker.
Assuming of course you just drained the radiator and not the block. New engine probably better to mix first.
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
