Coolant Temperature Sender
Old May 9, 2022 | 03:07 PM
72buickgs's Avatar
Car: 1984 Trans AM
Transmission: 700-4r
Anyone have a GM part # for the sender for 1984 T/A 305 or a source for a correct sender for temp gauge in the dash (not idiot light)?
The unit I search for on Summit Racing, Napa, Rockauto are not like the unit in my car.
It has a clip, single wire, that slides perpendicular onto the sender extension that looks like the letter "T".
Thanks.
Old May 9, 2022 | 04:05 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Coolant Temperature Sender
My memory is foggy on this but iirc the old style sending unit is either completely superceded, or very close to it, with the newer style sending unit.
edit: I may be thinking of the wrong one.
https://www.thirdgen.org/forums/tech-general-engine/779040-sensor-identification-help.html#post6450216
Old May 9, 2022 | 05:38 PM
Right: AFAIK it hasn't been possible to buy a sending unit with the old "mushroom" connector for over 30 yrs now.
Not to worry though; the connector in the car plugs right onto a regular spade terminal like it was meant to.
Old May 9, 2022 | 07:16 PM
72buickgs's Avatar
Car: 1984 Trans AM
Are u talking coolant sensor or coolant sender. Not the same. The sender is in the driver side between cyl 1 & 3 on the block. The pictures in the other thread look noting like what I have. Mine is also single wire. The block is the grounder. See the picture. It is for 1966 +/_ c10 v8 pickup. Old school.
Old May 9, 2022 | 07:33 PM
I'm talking temp gauge sending unit. Exactly what's in your photo, except that your photo is the REALLY OLD style, with ½" pipe threads. Heads since mid-70s sometime have 3/8" pipe instead. That's exactly what you can't buy anymore AFAIK.
Doesn't matter though; the connector in the car plugs right onto a regular spade terminal - the kind you CAN buy - like it was meant to.
Old May 9, 2022 | 08:52 PM
72buickgs's Avatar
Car: 1984 Trans AM
I understand u now, Sofaking. I will as u state. Tkx
daturbosix
Nov 16, 2012 06:59 PM
My1986IROC-Z
May 20, 2005 09:11 PM
Nikon02
Jan 6, 2005 11:56 AM
Speedemon171
Aug 3, 2002 08:07 AM
antnyws
May 21, 2002 09:40 PM
