PROM tuners?
Old Jul 14, 2022 | 09:23 PM
TheMagikMan's Avatar
Car: 1986 Firebird Trans Am WS6
Engine: Cammed 358 TPI
Transmission: Built 700r4
Axle/Gears: 2.77 Borg-Warner 9 Bolt
PROM tuners?
I'm migrating my TPI system from my 305 to a new hydraulic roller 350 with 370 casting heads and a comp cams 08-502-8 camshaft running around 9:1 compression on 87 octane. I need someone to tune the PROM/Memcal unit and was wondering what positive experiences people have had in the past and what injectors you would recommend using, and whether or not the stock fuel pump can keep up with either 24 or 30lb injectors, which are the two numbers I'm on the fence between from south bay. It's going to be a daily driver so I'm not looking for a crazy race tune or anything but somewhere in the neighborhood of 330-350 crank would be great if at all possible. camquest is giving numbers in the neighborhood of 338hp/430ftlb.
Old Jul 15, 2022 | 06:12 AM
hessm70's Avatar
Engine: 355 TPI w/AFR 195s Dyno Don Headers
Axle/Gears: Borg Warner 9 Bolt, 3.27 gears
Re: PROM tuners?
I would recommend @Tuned Performance . He worked with me even before I was able to datalog then after I got my Moates link working, he dialed it in. You may want to shoot him a PM and start the conversation of what you may need.
Old Jul 15, 2022 | 07:41 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: PROM tuners?
If you are in PA and can get the car to greensburg i can assist you. Street and dyno tune at FJ Performance
Old Jul 15, 2022 | 10:58 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: PROM tuners?
Best to do live if you can, if you need assistance hit me up
vilespankmachin
Aug 31, 2014 11:50 AM
Shaggy350ss
May 30, 2004 07:04 PM
Team FTS
Aug 14, 2002 11:56 AM
badgmc
Feb 4, 2001 11:54 PM
