Starts, Runs great for 2 Minutes then dies
Old Sep 12, 2022 | 12:50 PM
L98FORM89's Avatar
Car: 1989 Formula 350
Engine: 355 HSR
Transmission: Rossler 700R4
Axle/Gears: 9 bolt/3.27
Hey everyone,
Been awhile but I'm back with a question.
Car starts and runs great for about 2 minutes, dies and won't restart for 5 or 10 minutes. Then it will fire right back up and repeat. The idle gets a little rough for a second then just cuts off.
I replaced the ICM in the distributer, same problem. Looking for next steps.
Anyone experience this before?
Any help is greatly appreciated.
Old Sep 12, 2022 | 03:00 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: Starts, Runs great for 2 Minutes then dies
When the car will not restart for 5-10 minutes. This is the time to check for fuel and spark. I'd hook a fuel pressure gauge to your fuel rail and crank the car. Make sure you have 40+ psi. If you do, then I'd get a spark tester (or just use a spare spark plug, ground it, and see if there's spark when cranking).
I had a similar issue. It would randomly turn off like someone flipped a switch. Sometimes it would restart. Other times it wouldn't. Other times it would start, idle for a few seconds, then die. It was completely random. I had 40+ psi at the fuel rail. And I had spark. I was chasing my tail for a month. Then I got a noid light from AutoZone. Hooked it up to one of my injector connectors. I'm watching it blink as the car's idling. All of a sudden it stops blinking and the engine dies a few seconds later. I try to restart, it won't fire, and the noid light is not blinking when cranking. Let it sit a while, crank the car, the noid light is blinking and the car fired. Long story short the injector driver in my ECM was flakey and would randomly stop working. Put a new ECM in and problem solved.
Old Sep 14, 2022 | 06:25 PM
L98FORM89's Avatar
Engine: 355 HSR
Thanks, waiting for a fitting for my gauge.. Then I will test.
Just as a fyi, when it dies and won't start, the fuel pump does engage. For what that's worth.
Thanks again for the quick response.
Old Jul 22, 2023 | 09:24 AM
L98FORM89's Avatar
Engine: 355 HSR
Been a year but....
OK checked fuel pressure, it was good.
Hooked up an inline spark tester. Car ran for a couple minutes, died. Tried to restart and tester didn't light up when cranking.
So, I am assuming it's spark related. I have already replaced the ICM, even swapped out an old distributor.
The ICM I put in was from Advance Auto, not sure how much that matters.
I was thinking of getting a Jeg's distributor, in the reviews someone said they had been blowing through ICM's and that distributor seemed to fix that problem.
I have the original and a MSD distributor now. FYI, I have an MSD 6 ignition.
Any ideas?
Old Jul 22, 2023 | 09:55 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
The msd box could be a problem too. Disconnect it from the system and test it. If it still has an issue you can always reinstall it. For right now, remove another possible thing to be a problem.
Old Jul 23, 2023 | 05:51 PM
BadSS's Avatar
Sounds like the coil to me. They’ll do that if there is a bad ground or on the way out. Double check your grounds and as said bypass the MSD box to rule that out. Good luck.
Old Oct 21, 2023 | 01:25 PM
L98FORM89's Avatar
Engine: 355 HSR
Nice call Aliceempire.
MSD 6-AL was the problem after all.
Hooked stock ignition back up, all good.
Thanks everyone for your input.
randyz91
Oct 1, 2010 04:57 PM
