No closed loop, int changing , no blm . New 02 sensor . Any ideas? Some screen shots
Old Sep 20, 2022 | 05:09 PM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
Old Sep 20, 2022 | 05:11 PM
Engine: 5.7 l98
Re: No closed loop, int changing , no blm . New 02 sensor . Any ideas? Some screen sh
I see I'm running rich , why wouldn't I be moving into closed loop.
Old Sep 20, 2022 | 05:13 PM
Engine: 5.7 l98
Also if I am not in closed loop is it normal for int to be adjusting
Old Sep 20, 2022 | 05:34 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Pictures are unclear I assume it’s some screenshots of winaldl. Int is moving and is low but no cl ?
Old Sep 20, 2022 | 05:39 PM
Engine: 5.7 l98
no closed loop flag, int back and forth between range 126 and 131. Pics are clear on my end if I click and zoom , can you not see them that way?
Old Sep 20, 2022 | 05:45 PM
Engine: Lb9
Transmission: M20
Might try reconfirming cl with tunerpro rt $32b adx. Using a phone the images I can’t see that well.
Old Sep 20, 2022 | 05:47 PM
Engine: Lb9
Transmission: M20
what’s the average o2 voltage , are you smelling fuel or something?
Old Sep 20, 2022 | 06:09 PM
Engine: 5.7 l98
I tried zooming some
Old Sep 20, 2022 | 06:16 PM
Engine: 5.7 l98
no smell of fuel. 02 in raw is 32,167,15239,106,165,46,127,125,55,51 were the last screen shot...
also noticed 02 count is 126 constant
Old Sep 20, 2022 | 06:55 PM
Engine: Lb9
Transmission: M20
Counts are swing point not sure what raw converts into mv. Can you manually check flag to see cl operation?
Old Sep 20, 2022 | 07:08 PM
Engine: 5.7 l98
yes I can see closed loop box and it is never checked
Old Sep 20, 2022 | 07:10 PM
Engine: 5.7 l98
I will try confirming with tp. Is $32b a certain version?
Old Sep 20, 2022 | 07:16 PM
Engine: 5.7 l98
I have tuner pro downloaded how do I import the version? Thanks
Old Sep 20, 2022 | 07:18 PM
Engine: Lb9
Transmission: M20
If you don’t have the adx convert ads
Old Sep 20, 2022 | 07:52 PM
Engine: 5.7 l98
thanks appreciate the help but I have never used tp rt before. I have it downloaded on my laptop but have no idea how to start using.
Old Sep 21, 2022 | 09:49 AM
Engine: Lb9
Transmission: M20
Use the tool bar, connect with blue arrows in 10k. Remover jumper or flip switch on aldl cable and hit record button. If your starting with a ads convert under acquisition iirc.
Old Sep 21, 2022 | 01:41 PM
Engine: 5.7 l98
thank you. Trying to figure this out. So the cable I have will work? I believe it's on 10ohms. Do I have to switch it? I tried recording and just got continous error count?
QwkTrip
Nov 25, 2020 07:32 PM
gt4373
Jan 25, 2018 08:04 AM
novadk13
22
May 13, 2004 06:29 PM
DeathZ
Pacific Northwest Region
Jun 18, 2001 02:36 PM
