Tech / General EngineIs your car making a strange sound or won't start? Thinking of adding power with a new combination? Need other technical information or engine specific advice? Don't see another board for your problem? Post it here!
1984 Trans AM 5.0 engine
I am looking for a part# for the NEGATIVE battery cable, be it AC Delco or GM OR an aftermarket source.
Would 4SD25x be correct. I assume that "25" means 25 inches
Reason: Should be negative cable
The local autozone had lots for my car. The standard cables were 4 gauge but the "golds" were 2 gauge which were fine by me and in several different sizes.
