Heated 02 power?
Old Oct 1, 2022 | 01:34 PM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
Heated 02 power?
I am about to install heated 02 sensor , where is everyone hooking the power side? What is the best option for ignition on power?
Old Oct 1, 2022 | 02:30 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: Heated 02 power?
I ran a fused wire from the fuse box "ign" terminal out to the 02
Old Oct 1, 2022 | 03:12 PM
Engine: 5.7 l98
ok. I see others ran from fuel pump also. Thanks
Old Oct 4, 2022 | 03:17 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
It's been a while. I also found somewhere in the fuse box (might have been "ign" terminal) that only got power with the car running. Used that and been fine for years.
Old Oct 4, 2022 | 04:14 PM
Engine: 5.7 l98
How are you getting to the fuse Box are you drilling a separate hole through the firewall?
Old Oct 4, 2022 | 06:16 PM
Vader's Avatar
Instead of punching through the firewall, the power supply to the cold start injector (purple wire) is already in the engine compartment, is not used for more than a couple seconds, and is fused at 3A.
Just for grins, I just tested a spare sensor heater on a regulated bench supply, and at 14.2V (typical charging voltage) the heater current stabilized at 880mA after a few second of the initial surge to about 1.3A. The cold start circuit should handle that nicely.
Old Oct 4, 2022 | 06:35 PM
Engine: 5.7 l98
I think I am going to delete the injector anyway. The purple is a constant 12v?
Old Oct 5, 2022 | 12:37 PM
TTOP350's Avatar
The cruise harness rubber gromet is where I put mine through. Poke around in your car and you may even find a better place
Old Oct 5, 2022 | 02:19 PM
Car: 1988 IROC-Z
Engine: 427 SBC
I found a spot where wire were already coming through. I was able to squeeze the wires through.
91 z28 350
Dec 24, 2001 07:48 PM
