Lunati 20080660 roller cam with tbi heads
Old Nov 10, 2022 | 07:31 PM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Axle/Gears: 3:42 open diff
Hello everyone, I was wondering if anybody has used this cam with stock 193 heads. I was initially thinking of going with a 1994 LT1 cam. Part of me wants a little more cam. I was going to use comp 981-16 springs. Do you think I would need to cut down the guide bosses.
https://www.lunatipower.com/efi-hydraulic-roller-cam-chevrolet-lt1-lt4-279-287.html
Old Nov 10, 2022 | 07:54 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Lunati 20080660 roller cam with tbi heads
https://www.lunatipower.com/efi-hydr...4-279-287.html
Most are good for 0.500 with more than 0.050 additional, but it varies enough they should all be measured.
Old Nov 10, 2022 | 08:39 PM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Ok thanks, how would I go about measuring it. Also do you think I would still make some decent power even with the 193 heads even in stock unported form. I know I probably would have to do some tuning. I was also thinking about taking a crack at some bowl blending as there is a big ridge under the seat
Old Feb 25, 2023 | 10:43 AM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Hello everyone it’s been a few months anybody have any ideas. I would greatly appreciate some help!!
Old Feb 27, 2023 | 08:50 AM
BOOT77's Avatar
Should check/mock up your exact parts to be sure. Even well know combos can run into problems sometimes due to manufacturing differences or part changes. Sometimes the out of tolerances all stack up.
Old Feb 27, 2023 | 12:06 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
I think this is what you are asking...
This fellow used to be a member here, though I think he mostly posts on YouTube these days. In the first half of this video he's talking about checking valve spring retainer-to-valve stem seal clearance at full lift. He's using Vortec heads, and LS spring dimensions, but the method should be valid for any SBC head.
You'll need to know your max lift numbers...so look at your cam specs, and multiple by whatever rocker arm ratio you will be running. Don't forget to account for CLEARANCE as he describes in this video.
I'm sure you can poke around on YouTube and find other videos as well, using other methods.
Old Mar 4, 2023 | 08:05 AM
zupta82's Avatar
Car: 88 Trans Am
Engine: 305 TBI
Ok thanks everyone, one last question do you think tuning would be reasonably feasible with this cam. From what I can gather this cam is considered a slight upgrade for lt1 and engines.
Evilution
Jun 24, 2012 08:25 PM
trans_am_ta_84
Apr 19, 2004 06:48 PM
Dewey316
Feb 25, 2003 08:36 PM
TBIWorks
Feb 21, 2002 02:01 PM
