Total Advance timing
Old Jan 20, 2002 | 07:17 PM
NORT's Avatar
I have a 355ci. chev. with a 268 extreme Comp cam, vortec heads, 750 Holley, Headers all the basic stuff. I'am trying to get the timing right and i'am not sure what it should be, base line as well as total advance timing. I know this can very from motor to motor but I would appreciate some imput. I tried it at about 38 total and I have quite a bit of spark knock. If someone could get back with me it would help alot!!! Thanks NORT
Old Jan 20, 2002 | 08:12 PM
giovanhalen's Avatar
Car: 1984 Z28
Engine: 454
Transmission: Th400
Total timing of 34 degrees will probably work. It also depends what rpm your total is coming in at. If the curve is too quick it could cause pinging. If you are using vacuum advance it could cause a problem at part throttle if you have too much vacuum advance, but wouldn't affect full throttle operation. If you are at high altitude you would need to retard timing a little more.
Old Jan 20, 2002 | 09:01 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
vortecs should be kept to about 34max
start with about 10 to 12 degrees initial. Don't let it start advancing b4 about 1200 and try to get it all in by about 3200 rpm. most factory dists are limited to about 18degrees internally.
Vintageracer
Jan 10, 2020 05:33 PM
bellez77
Sep 5, 2015 08:39 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
