fireing order?
Old Jan 20, 2002 | 07:26 PM
88_RS&86_Z-28's Avatar
fireing order?
can anyone give me chevys fireing order i pulled all my wires off today and thought i had it writen down but i guess not and its a performer RPM intake so its not on there .
And one more ? i cant seem to get my car to start it will trun over but it wont start its like i have no spark i know the fireing order was correct before i took them off cause it ran before then
i dont have a timming light nor do i have a timming mark and the blancer and i pulled the marlloy dual points and iam swapping it with a GM HEI that i had laying around i was told i would get more performance out of it does the HEI need an ext. coil or is on top? iam pretty sure its on top thats why theres two pulgs one says tach and one says battery
sorry its so long
Old Jan 20, 2002 | 08:12 PM
ede's Avatar
ede
18436572
Old Jan 20, 2002 | 08:41 PM
83 MidniteZ's Avatar
You should know those numbers like your Social Security Numbers
Old Jan 20, 2002 | 09:11 PM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Old Jan 20, 2002 | 09:35 PM
Vader's Avatar
Old Jan 20, 2002 | 09:54 PM
grumpygreaseape's Avatar
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
uno mas thing-clockwise distributor rotation for s.b.c.-b.b.c. too
Old Jan 21, 2002 | 10:58 AM
cfabe's Avatar
on that dist, its a coil in cap setup. You can put it in as long as its not a computer controlled one. All you need is poewr to the batt terminal and the connector from the module that comes out the side plugs in behind the power connector. Use a 1/4" (i think) female spade connector for the power wire.
KCG
Jun 24, 2020 04:33 AM
djmarch
May 8, 2016 11:32 AM
camarohelp
Sep 22, 2015 03:19 PM
webeeZ28
Sep 14, 2015 12:00 PM
