Trying to choose the right push rod checker...
Old Dec 24, 2022 | 12:38 PM
EDGE's Avatar
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
My stock push rod is 7 3/16" long. I'm changing to 1.6 rockers on an aftermarket aluminum head. I'm trying to choose a length range on the test rod. How much do you generally add with a change like that? I assume we're talking in the thousandths, not inches. Would I be safe to get a Rod that's 6.8 to 7.5 inches?
Old Dec 24, 2022 | 09:29 PM
BOOT77's Avatar
Re: Trying to choose the right push rod checker...
How are you checking? If your doing the sharpie sweep method, make sure to use lightweight test springs. The comp test springs are too narrow for most seals, I just got some from my local hardware store.
With all my SBC projects cars(5) I just got the Comp Cams Hi-tech pushrod tools, need both since it > 7.8 & < 7.8 for flat tappet but sounds like your roller so the shorter one would be fine.
Pablo
Dec 10, 2012 07:43 PM
Reptile
Jul 21, 2011 05:05 PM
slow89
Feb 14, 2008 02:09 PM
SteelTownMadDog
Sep 6, 2007 01:35 PM
Fastcam
Nov 3, 2003 03:04 PM
