Bent Push rods!!
Old Nov 2, 2003 | 04:53 PM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
Transmission: 700 R4
Bent Push rods!!
I thought i had a rocker lose so iput it in the garage nd took it apart! I started torqueing themand i noticed one went down really far i was like what the hell. I took it apart and the push rod out and it was bent!! I chcked the rest and found 3 more. I was just wonderig if any off u guy guys have had this happen???
Old Nov 2, 2003 | 04:56 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Are your unning ratio rockers with stock pushrods?
Old Nov 2, 2003 | 05:00 PM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
Nope its all stock!!! I think i over reved it!
Old Nov 2, 2003 | 05:07 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Thats rare. Reason I asked if you were running ratio rockers is they put more of a strain on the pushrods. Its always advised to run hardened pushrods with 1.6 rockers.
Since the car is still stock configuration, you are most likely correct if you severely overevved it- Lucky nothing else cut loose. I thinking maybe you might have a bad lifter also. Have you ever adjusted the valves yourself in the past- Maybe one was set too tight/ or too loose for that matter with a bad lifter.
Old Nov 2, 2003 | 05:10 PM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
how do u adjust the valves?
Old Nov 2, 2003 | 05:13 PM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
one other thing how do u check the lifters?
Old Nov 3, 2003 | 02:31 PM
Skatepunk60's Avatar
Car: Hardtop 84' z/95' Cheyenne
Engine: 305 H.O./4.3L
Transmission: 5-speed manual/Auto
to check the lifters pull the intake and rocker arms and push rods then pull em out. For ptting it back you tighten it all down so theres no lash then run the engine .. back out the nut on the rocker stud till you hear a noise then torque it down till it goes away and give it like another 3/4 turn.
Old Nov 3, 2003 | 02:59 PM
Fastcam's Avatar
Car: 1986 Z28
Engine: 305 LG4
Do i have to the whole intake off or can i just get them from the push rod holes like on a old 350?
Old Nov 3, 2003 | 03:04 PM
TechSmurf's Avatar
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
On the engine-running valve lash, 1/4 turn to 1/2 turn after it stops ticking is generally accepted.. 1/2 turn is considered the safe bet. However, if you look at shop manuals for the past couple decades, you'll notice that the number of turns has been steadily decreasing over the years
And for the lifters, yeah, you gotta rip the top end apart.. upper/middle plenum, fuel rail, intake manifold, all go bye bye..
RedLeader289
May 28, 2019 01:47 PM
ZekeThorpe
Theoretical and Street Racing
35
Oct 7, 2015 07:30 PM
loud91rs
Oct 5, 2015 10:05 PM
skinny z
Oct 5, 2015 06:23 PM
J. Chris Davis
Interior Parts Wanted
Sep 28, 2015 11:55 AM
