Defroster Season again...
Old Nov 3, 2003 | 03:38 PM
mvftw's Avatar
My '86's defroster only stays on for 2 mins. I got another used defroster switch/timer, and that only stays on for 2 mins. Can they both be worn out? My grid seems Ok. Does Chevy still sell them, if so how much? Or is it something else?
Old Nov 3, 2003 | 06:25 PM
camaro_junkie's Avatar
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
I believe that they are purposely timed so that you don't leave it on indefinitely. I don't think there's any harm in turning in on again after it has shut off a couple of times, but imagine if you left it on for a couple of hours of driving, you might burn up the grid. Notice that the switch is not a two-position switch, it's click-on/click-off/center (high-impedance?). Hope this helps.
Old Nov 3, 2003 | 07:07 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
They're usually timed for 10 minutes or so. Sounds like yours may be overloading, maybe due to a poor connection at the ground wire on the passenger side. Check all the connections on the struts to be sure they are clean and tight.
Pete
bjpotter
Oct 15, 2015 11:07 AM
darwinprice
17
Oct 11, 2015 11:51 PM
whibbs
Exterior Parts for Sale
Sep 28, 2015 07:53 PM
J.C. Denton
Sep 8, 2015 05:35 PM
scottmoyer
Sep 7, 2015 07:06 PM
