Are there replacement harness connectors available?
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
I need to replace my IAC connector, it's falling apart and the alternator one as well. They're both in pieces. They work but they don't lock in place. Are these available anywhere?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Are there replacement harness connectors available?
If the alternator is cs might have to get the pigtail, mouser has the iac connector
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Engine: Lb9
Transmission: M20
https://www.waytekwire.com/item/3808...tiv%20Products
just might want to verify slit locations , I think that’s the right part number
You can buy the various pin-count/gauge/shape/type/style weather pack connectors on ebay & amazon, bulk has a good rate sometimes. I bought multiple sizes for my project car wiring needs.
https://www.ebay.com/itm/26483281749...3ABFBM6Iy5kb1h
Car: 1987 GTA
Engine: 5.7
Transmission: T5WC
Axle/Gears: 3:27
Just checked Rock Auto. They appear to have every connector for the harness. From Delco original to aftermarket.
Maverick H1L
Sep 10, 2013 07:00 PM
