No start
No start
86 iroc has been sitting for years. I replaced the fuel pump and relays. When ignition is turned on pump does not run and no lights come on in dash. Any ideas where to start would be appreciated.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: No start
Power to the relay ? Power and fuse is good next to the battery ?
Car: 1989 IROC-Z
Engine: L98 350 TPI
Re: No start
Start at the battery and move forward until you lose juice. Check grounds and cables, have a look at the power distribution at the starter.
Engine: Lb9
Transmission: M20
Re: No start
may need to check fusiable links on starter for the no power inside the car. Thread
