Need help with wiring
Old Mar 14, 2023 | 06:57 AM
Shreddster's Avatar
92 Firebird 5.0 T.B.I. 5 speed trans...Greetings, I had a engine fire and I' need help with battery, alternator and starter wiring. I've replaced the burnt wiring and I can't figure out what wires go to the power junction block or if the charge system is true. I'm a dummy for wire schematics. I have spark, blinker and gauges but no lighting or even that annoying ignition chime . Please help. Thank you
Old Mar 14, 2023 | 08:21 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Need help with wiring
Where was the fire? The interior dome lamps and buzzer are tied into the doors/hatch and feed off the headlight switch (white wire). That is in the dash harness though.
Old Mar 14, 2023 | 09:49 PM
vorteciroc's Avatar
Top Answer: 1
Honestly if your not experienced with this scale of Wiring/ Electrical Repair and reading/ understanding Line-Diagrams, Block-Diagrams, and Schematics...
I would recommend purchasing some used Harnesses to replace your Damaged Wiring.
Reach-out to @John in RI here on the Forum...
He sells all the different Harnesses (used) for our Cars.
Best of luck to you!
jason_yeast
Oct 29, 2011 04:42 PM
Whoboy580
Jul 1, 2007 12:41 AM
pawcio
Apr 14, 2006 09:20 AM
jeepguy553
Mar 25, 2004 01:20 PM
