New valve covers needed???
Old Jan 21, 2002 | 10:52 AM
92RSB4C's Avatar
Well, I got almost all the Comp Cam Roller Rocker arms back on and I was test fitting the stock valve covers and they don't fit. The problem is the support in the middle of the cover hits the arms and won't go past them. Has anyone else had this problem? If so, what'd ya do to fix it?
Oh, I have a L98 out of a 92 RS, and the heads were replaced(with iron) before I bought the car.
Old Jan 21, 2002 | 02:52 PM
ede's Avatar
ede
i did with comp 1318 rockers. if you can buy taller valve covers that would be the easiest way out. i took a extra set of valve covers and cut them up and cut up waht i had and welded them together. took a while to do it but it works.
Old Jan 21, 2002 | 06:40 PM
92RSB4C's Avatar
Are there any taller center bolt style valve covers?
Here's my problem in a picture. There's not enough space between the rockers and the pcv valve baffle gets in the way.
Old Jan 21, 2002 | 09:54 PM
robertg's Avatar
Car: 2000 astro
Engine: 4.3
Transmission: A4
Axle/Gears: 7.5 with 3.42 gears
92,
Jim Pace www.paceparts.com carries tall-style centerbolt valve covers. I think they're made by TD Performance. Pace offers a free catalog. check it out
Old Jan 21, 2002 | 10:31 PM
92RSB4C's Avatar
Thanx, but I checked out moroso.com and I think I found what I needed! Thanx for the help though!
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
Street Lethal
Aug 12, 2015 11:33 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
mustangman65_79
Aug 8, 2015 01:18 AM
