Remove old gas.
Old May 15, 2023 | 11:35 AM
hapbobg's Avatar
Remove old gas.
I have 1991 camaro rs convert. How do I go about getting old gas out of car? Car was put away for winter but I had health probs so car was out of use for 3 - 4 years. Thank You.
Old May 15, 2023 | 07:13 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: Remove old gas.
Fuel pump still work? Disconnect a line, put it to a gas can, jumper the fuel pump relay. Let the pump do the work
Old May 15, 2023 | 07:52 PM
SbFormula's Avatar
Car: '18 Chev Camaro SS 1LE
Engine: LT1 6.2L
Axle/Gears: 3.91
Re: Remove old gas.
... and get ready for 60psi of pressure coming out into the jug or whatever you're going to use!!!!
Old May 15, 2023 | 08:55 PM
Aaron R.'s Avatar
Car: 1985 Z28
Engine: 305 LG4
Re: Remove old gas.
Top off the tank with some fresh gas and drive it around until near empty, then refill. My boat sat for a good 3 years without running. Just fired it up this spring and drove it without even adding fresh gas.
Old May 15, 2023 | 11:10 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: Remove old gas.
Get a 10-dollar hand-operated pump from harbor freight or online. Disconnect fuel line and connect hose on the inlet of the pump. Pump out the old gas into a large gas can.
I've done this on 2 cars and it's easy and takes only a few minutes. The most inconvenient part is crawling under the back of the car...
Daniel89TA
Apr 14, 2022 12:35 PM
ramuto
Dec 3, 2011 05:27 PM
Xenodrgn
Dec 12, 2002 07:26 PM
