485 crank hp from a 383, Miniram AFR 195 Street port, what cam?
Old Aug 30, 2023 | 11:06 PM
Yakmastermax's Avatar
Car: 1989 Corvette, 1991 Corvette, 1985
Transmission: ZF6 and 4+3
Hey guys
My goal is a 485 crank horsepower 383
Currently have a converted LT1 intake manifold, but I am open to getting a Miniram if I have to. LT1 manifold should flow around 310 CFM
Scat 9000 stroker crank, Eagle SIR 5.7" rods, Icon forged 9914-030 pistons.
Aiming for 10.7:1 compression with the AFR 195 street heads, 65 cc combustion chamber. Flows 275-280 CFM from 0.500-0.550" lift
What cam will get me to 485 chp?
236/242 duration 0.576" lift?
Or do I need bigger heads?
6300-6500 RPM redline track car.
Will the miniram outperform the converted LT1 intake?
Thanks guys!
Old Aug 31, 2023 | 11:58 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 485 crank hp from a 383, Miniram AFR 195 Street port, what cam?
A 1205 miniram would be slightly better, but doubt by much. Not worth the upgrade. If the heads were bigger with a 1206 port then a 1206 ported miniram would be better
id keep the lt1 for now if the ports match the heads. Guys have pushed those pretty far.
236/242 is ball park imo. Check out advanced inductions lt1 cams. They have done this combo before but with slightly better heads of theirs. But i think you’ll be happy with something of that spec. 110 lsa or so. Bit rough idle but do able. Those lt’s have always done decent with tight lsa’s.
Old Aug 31, 2023 | 01:14 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
218/228 on a 108 LSA and 106 ICL with 0.578 lift is enough to get a 383 over 500 hp, I know because that is what is in mine. Lloyd Elliot speced several of the cams in Karl Ellweins 383 LT1 builds and they have gotten around the 500 hp mark. I would expect the cam you have in mind to make about 530-550 hp and peak closer to 7K.
This one had the old GM 846 Crane 109831 cam. 222/230 on a 112 LSA. It made 500 hp and 527 TQ. With good heads the cam does not have to be nearly as large as some believe to make great power. Case in point the little 222/230 peaked at 5,900 rpm and was still making 485 hp @ 6,200. 527 ft/lbs @ 4,000. It actually made those numbers with a dual plane intake and a carb. A short runner EFI intake like the MiniRam will carry the power longer up top.
http://www.ellweinengines.com/ERE45/ERE45.htm
Old Sep 1, 2023 | 09:48 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
it could maybe on high compression and absolute killer heads, but i wouldnt call afr 195’s out the box all that killer. They are nice tho. At first i thought he meant the enforcers so i went bigger on cam.
​​​​​​​Did you ever get actual dyno numbers on that combo?
230 deg hyd roller is about 400 whp in afr 195 street heads. Some see abit more. For most builds in most dynos. 6250 rpm ish peak. Shift by 6600. Thats how mine was.
Old Sep 1, 2023 | 10:56 AM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
412 hp and 430 tq at the tire on a Mustang Dyno through a 4L85E in 2nd gear and a GM 10.5 14-bolt.
At 6,940 lbs, 4L85E with a stock diameter custom built converter flash stalling ~2,900 rpm and a 3.73 gear it went 9.1 @ 74 on a 2.1s 60' in the 1/8 in 3,600 ft DA. It needs gears or a 6L90E swap badly.
z28yourstang
Feb 13, 2014 03:07 PM
CamaroCrazy23
Feb 6, 2006 10:45 AM
tamatt27
Feb 4, 2004 04:19 PM
KYL98
Dec 2, 2002 01:37 AM
