dis. gear
Old Jan 22, 2002 | 12:23 AM
88_RS&86_Z-28's Avatar
dis. gear
what do you have to do to get that dam thing off the end of the dis. one of the teeth broke on it and i have to replace it. or will it work if one is broken its only about half way gone
Old Jan 22, 2002 | 12:39 AM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
You have to tap the little retainer pin out.
Old Jan 22, 2002 | 12:42 AM
88TAJeff's Avatar
Car: 88 T/A
hi 88,
It's fairly easy once you get the dist. out. Just drive out the pin under the gear, and if the gear still doesn't come off, some WD-40 will do wonders. Just work it back and forth and it'll come off, trust me.
Old Jan 22, 2002 | 08:09 AM
alright sounds good guys i will do that next time iam over at my car. i have to buy the new gear frist and will the new gear come with a new pin or should i use the old one and try not to loose it
Old Jan 22, 2002 | 09:48 AM
Engine: LH0 3.1L
I've always used the old pin. If the new gear comes with a new pin then use the new pin.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
