4th gen gas tank install using TPI
Old Sep 28, 2023 | 08:46 PM
Nutro's Avatar
So, I have the wiring sorted from the tank to the car, I have the sender squared away, the fuel supply and return lines are done. The charcoal canister on the 2002 fuel tank is still there and I will let it vent to the 4th gen canister. The part where I am lost is, what do I do about the charcoal canister/evap purge etc from the car? I'm assuming the ECM will freak out and set a code if there is no purge event?
thainglo
Jun 22, 2020 04:56 PM
WTR388
Mar 4, 2015 10:49 AM
craig
Carburetors
Dec 5, 2007 10:03 AM
irocz2889
Nov 23, 2007 09:46 PM
