high rise vs low rise manifolds in colder climates
Old Oct 19, 2023 | 04:30 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
my engine is a L31 383 stroker, comp cams xe282hr cam, edelbrock performer rpm air gap intake, Demon 750 carb. as the weather gets colder in New England, I have to really let it sit on the fast idle and get some heat into the manifold and carb for fuel atomization. the air gap intake definitely isn't helping my situation with the obvious gap of air paired with not having an exhaust crossover. This is making me want a more street friendly/ cold weather friendly intake. Hood clearance is of no concern.
I was considering getting the regular edelbrock performer rpm intake manifold but decided to check out other brands beforehand. I see Weiand offers a low rise and high rise warrior intake, both with exhaust cross overs and no air gap.
1. https://www.holley.com/products/engi...e/parts/8150BK
2. https://www.holley.com/products/engi...e/parts/8120BK
My concern is that the powerband of the high rise with longer runners suits my stall and cam better but I don't want another tall intake that takes forever to get heat into it. Is this a reasonable concern or does it not really matter between these two intakes since they both don't have an air gap and both have an exhaust crossover?
Old Oct 19, 2023 | 05:47 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Re: high rise vs low rise manifolds in colder climates
Since the intake is aluminum and not an air gap, I'd think that the heat would soak through the intake at a pretty similar rate, either style.
Old Oct 19, 2023 | 06:44 PM
T.L.'s Avatar
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
The Performer RPM does not have exhaust cross-overs.
The Weiand does if I remember correctly...
Old Oct 19, 2023 | 07:18 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
The RPM manifolds DO have the exhaust heat crossover provided they are for a traditional cylinder head and not a Vortec. The Vortec one has a hot coolant crossover.
Old Oct 19, 2023 | 08:37 PM
T.L.'s Avatar
'Sorry, I AssUMed that it didn't since the Performer RPM for the small block F#rd doesn't have the exhaust cross-overs (I wonder why that is)...
Old Oct 20, 2023 | 03:09 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
That is odd that Edelbrock decided to do that on the SBF manifolds. The RPM is designed to be a high performance street manifold. With a carb, cold weather drivability gets wrecked without some kind of plenum heat.
Wildebird
Nov 15, 2007 05:14 PM
stevenb
Nov 14, 2007 08:17 PM
327???
Jul 15, 2006 03:35 PM
WaaX
May 26, 2005 10:27 PM
matt_82transam
Carburetors
May 22, 2004 01:44 AM
