Intermediate shaft
Old Dec 14, 2023 | 10:31 AM
george88gta's Avatar
Car: 1988 Pontiac GTA
Engine: 5.7 l98
Axle/Gears: BW 9bolt with torsen carrier
Intermediate shaft
Just installed new intermediate shaft , I noticed the four nuts and bolt at the steering box end of shaft were loose after install. Went to tighten them but they compress the rubber bushing on that end. Soooo the question is how tight do I go?
Old Dec 14, 2023 | 04:32 PM
Engine: 5.7 l98
Re: Intermediate shaft
Is there a torque spec?
Old Dec 14, 2023 | 05:32 PM
Vader's Avatar
The clamp/pinch bolt for the input to the steering box should be tightened to 30 ft/lb.
Does the rag joint have the semicircular metal inserts that distribute the force of the fasteners? With those, a Haynes manual indicates 20 ft/lb for the nuts, but I don't completely trust many of those aftermarket manuals.
Old Dec 14, 2023 | 07:32 PM
Engine: 5.7 l98
Not sure of what you mean by inserts but here is a picture
Old Dec 14, 2023 | 08:40 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Thats not an OE piece, so its anyone's guess what the "correct torque would be, but i would avoid squeezing the rubber piece too much. Its also not collapsing like the original. Looks like that was used for clearance issues maybe. The OE rag joint is riveted/collapsible piece which i believe they repo that now.
Old Dec 14, 2023 | 09:37 PM
Engine: 5.7 l98
it's not OE but it is a collapsible shaft.
JamesC
Sep 19, 2019 08:58 AM
6speedIROC
Nov 5, 2017 07:31 PM
formula_novice
Aug 20, 2013 03:10 PM
Mark A 91Formula
Feb 19, 2013 01:23 PM
andy625
Nov 11, 2007 04:44 PM
