Crate Engine warning
Old Feb 2, 2024 | 06:25 AM
Old Guru's Avatar
Ask yourself why a Blueprint 383, with bespoke 195 heads, 10:1 static compression, and a cam that makes 450 HP with Vortec heads and 9.1:1 static compression, only makes 436 HP?
The answer is Blueprint's heads aren't competitive. Worse, you hafta pay for them to get Blueprint's SBC 454 short block assembly, or their BBC 598 short block assembly.
Blueprint also puts their shizzy 195s on their 350s, and unless you want a 7500 RPM race only 350, a 195 is too big for a 350. You can hit 500 HP with any of the top 3 180 heads and a reasonable cam.
In my experience, RHS had some excellent heads that I can no longer find new, anywhere, on par with AFR and Dart. They're the top 3 for flow, and the top 3 for quality.
Coast High Performance specializes in, or is at least known for, Fords, but they have a contract with AFR, and they will sell you whatever you're able to pay for. Their results are excellent.
Old Feb 2, 2024 | 07:46 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Crate Engine warning
I am not sure I understand what you are doing with these posts.
Old Feb 2, 2024 | 10:27 AM
badtenant's Avatar
Car: 92 RS
Transmission: TKX
I assume day-drinking
Old Feb 2, 2024 | 02:12 PM
vinny R's Avatar
Car: 1991 Z28
Axle/Gears: 3:42 Auburn
So this is how AI will infiltrate our board.
Old Guru
Feb 1, 2024 04:28 AM
Street Lethal
Jul 22, 2022 04:32 PM
r0nin89
Sep 13, 2006 10:27 AM
1badrocZ
Apr 19, 2006 08:42 PM
steve88iroc
May 24, 2002 04:23 PM
