Aftermarket Fuel Tank
Old Mar 3, 2024 | 09:53 AM
MarcA's Avatar
Question. I replaced my fuel tank on an 85 IROC with a Ricks Tanks.
It did not come with a filler neck attached to the tank. As most are aware of the stock tank has a ridged filler neck built into the tank so no upper support is needed.
Does anyone know of an aftermarket filler neck that can be attached to the Ricks Tanks fuel tank, fit to the factory fuel door opening, and have a support mounting mechanism up top?
Old Mar 3, 2024 | 06:21 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Aftermarket Fuel Tank
You could probably use a stock 4th gen neck which consists of a flexible hose section.
Old Mar 6, 2024 | 08:06 AM
MarcA's Avatar
Looks like I am going to have to fabricate a mount to hold the upper neck up and stable while filling anyway. Limited access but even the Ricks tanks website states to use your stock filler neck. The problem is that stock filler neck on an 85 was soldered into the tank so not coming out without some risk.
Ill have to look at the 4th gen and see if the angles are right.
Squidlox
Jan 23, 2020 01:58 PM
trafficlightguy
Carburetors
May 11, 2017 07:26 PM
articwhiteZ
Aftermarket Product Review
Feb 21, 2016 02:43 AM
Joiner
Feb 14, 2009 09:54 PM
elthomas
Aug 14, 2008 12:57 AM
