Delphi Fuel pump from Rock Auto a dud?
Old Mar 3, 2024 | 06:51 PM
Keith Yee's Avatar
Hello Guys,
My buddy and I have painstakenly replaced the sending unit and fuel pump for my 87 iroc (Stock 5.7 TPI) We swapped the pump and it it constantly reads 38psi instead of 43psi but it is holding pressure. Should I get my refund back from this fuel pump? Did I purchased a bad Fuel pump?
Old Mar 3, 2024 | 07:02 PM
hessm70's Avatar
Engine: 355 TPI w/AFR 195s Dyno Don Headers
Axle/Gears: Borg Warner 9 Bolt, 3.27 gears
Re: Delphi Fuel pump from Rock Auto a dud?
I installed a Delphi pump and it worked for about 8 months (about 5k miles) and failed on the Hot Rod Power Tour. We replaced it with a Walbro 255lph.
The Delphi pump does not seem to be a quality piece.
Old Mar 4, 2024 | 11:53 AM
Sounds more like you didn't disconnect the vacuum from the fuel pressure regulator while measuring the pressure.
Old Mar 7, 2024 | 01:32 PM
Keith Yee's Avatar
I ordered a Walbro:
GCA758-2
This should be the correct model. Hopefully its a good quality pump
Old Mar 7, 2024 | 01:57 PM
hessm70's Avatar
Yep that’s the one I am putting in this weekend.
Old Mar 7, 2024 | 04:12 PM
Tom 400 CFI's Avatar
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
91GTABird
Dec 19, 2019 06:23 PM
-LateNite89-
May 13, 2013 09:53 PM
transamice
Sep 13, 2011 04:58 PM
