Newbie lq4
Old Apr 8, 2024 | 10:11 AM
lebreton90's Avatar
Newbie lq4
Hello, new here. And new to going more then stock builds!
Sorry in advance for maybe some dumb questions as I’m extremely new to this.
I picked up a Lq4 with 799 heads they are both bare, no internals.
my goals is to build a turbo Lq4 for a swap I have wanted to do for years now and finally got the chance to do it. I would like to get as much hp I can. And do it right the first time.
everyone I have tried to talk to says to just build a stock engine witch I have on a 5.3l lm7 but I didn’t pick the parts and that’s where I’m having issues
so crankshaft will be stock as I have read they can handle 1000hp
first question is how do you pick the right pistons, rings, and connecting rods
when I’m looking at pistons they bore listed is the same bore as cylinders on my block.from what I have read you want slightly smaller piston bores then they cylinders. What would be a good cam and lifters
next questions is how do you know what internals will fit into the heads? So how do you pick valves, valve springs push rods, rockers
sorry again big time newbie trying to learn here
[img]/forums/images/buttons/user_online.gif[/img]
Old Apr 8, 2024 | 11:17 AM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
Re: Newbie lq4
I wouldn't buy a single part until you do some extensive research on your goals. There are some good beginner LS build books out there and I suggest you buy a few and read them. While doing that, read all the stickies here in the LX swap forum and then reread them again. Learning is free and will save you money down the line. Set a budget for your project and be flexible enough to make changes and or amend your goals along the way. Since you are starting from scratch no one will be able to supply you with all the info you need in this thread. Best bet is to research and then research some more. Watch YouTube videos ect ect.
Old Apr 8, 2024 | 11:35 AM
lebreton90's Avatar
Re: Newbie lq4
Yes I I am just waiting on a few books to arrive!
thank you I will keep reading and watching YouTube videos
lebreton90
Aftermarket Product Review
Apr 8, 2024 01:49 AM
Emeraldsun
Mar 13, 2021 05:15 PM
Bryan Garcix
May 17, 2020 09:26 AM
grove
Dec 15, 2007 12:03 PM
Crisis
Jan 28, 2004 06:18 AM
