1992 25th Anniversary RS Revival
Old May 22, 2024 | 02:37 PM
gilgastelum21's Avatar
Hello All,
So I have a 92 RS 25th Anniversary Edition (148,XXX Miles, 305 V8, Manual Transmission, T-Tops) that was parked for roughly 5 years, and now that I have the means and want to get it going, I got a few quotes from some shops about reviving it, was told it'll cost roughly around $2500.00 - $3500.00 to get it going, said it would require a new battery, wires, plugs, coils, hoses, belts, water pump, thermostat, etc. due to some dry rotting going on. I am no Mechanic and just understand the basics, So my Question is if that sounds a bit too high of a price for parts and labor or is that accurate? I would like to dive in myself but I don't have the space or tools just yet to do anything myself at the moment.
Old May 22, 2024 | 06:28 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 1992 25th Anniversary RS Revival
i'd install new battery,see how much of the electrics are working,then check if the fuel pump still works-if it does(listen for the whirr in the tank)siphon out as much stale gas as practical,add about 5 gal fresh gas ,check oil ,and crank engine-will take a few turns to pump lifters back up.If engine does not start or try to start,pour about 1/2 cup of gas down TBI and see if it runs a few seconds Expect the injectors to be stuck and need freed up and if high humidity clutch disc could be stuck to flywheel/pressure plate from rust. Good luck
Old May 22, 2024 | 06:33 PM
thanks
Old May 23, 2024 | 04:15 AM
BigBlock73's Avatar
Car: 90 IROC original owner
Engine: 5.7
If it's a reputable shop getting about $100 hour, that what I would expect to pay.
Old May 23, 2024 | 12:14 PM
well from my understanding it is and well known, they have 5 star reviews consistently which is why i considered taking it to them but the price just seemed pretty steep for that amount of work which is out of my experience and/or knowledge. So perhaps the price is right in that case, thank you for your feedback.
Old May 23, 2024 | 03:56 PM
80schild's Avatar
Car: 87 GTA
Engine: 5.7 TPI
Axle/Gears: 3:27 BW 9 bolt
Kinda curious how they know the water pump and thermostat needs replacing when it's not even running?
Old May 24, 2024 | 12:15 PM
yeah i questioned that as well.
Jowada c-rs
Feb 13, 2018 03:37 PM
92Ramaircamaro
Members Camaros
Nov 18, 2017 03:41 PM
patrick92
Members Camaros
Apr 10, 2008 10:05 PM
camarosource
Jul 8, 2003 06:23 PM
