Slight miss
Old Jan 23, 2002 | 10:01 AM
89 CamaroIROCZ's Avatar
Slight Miss AND OTHER ?'s
Hey guys My engine has had a slight miss for awhile and i'm trying to figure out why it is happening. I looked for vacuum leaks and have come up short. I think I am pulling approx 19 pounds at idle which sounds correct. However, I can't get my idle down lower thn 1200 or else the car wants to stall out. I know it is running a little rich as well. Where should I be looking?
I know the cam isn't THIS big that i can't get the idle down. Help me out fella's. I'm thinking ignition problem. Maybe coil or module. Can you explain the ignition module to me as well? Thanks!
Matt
EDIT: Wires, cap, rotor, plugs are all new.
EDIT #2: Okk... noone is answering. Could timing keep me from achieveing idle lower then 1200 RPM??
Old Jan 23, 2002 | 06:21 PM
camarojoe's Avatar
Car: 91 Z28
Engine: Forged 383
Transmission: Pro-built 700R4
It's most likely a bad injector(s). I currently have a similar problem (slight miss at idle) and am going to get new injectors in the spring. I'm dreading it though cause of Da Ram. Good luck and do a search under injectors.
Old Jan 24, 2002 | 08:08 AM
i'm sorry i forgot to add my sig. I have a carberated crate motor with low miles. It has a used 650 double pumper on top which gives it more then enough fuel.
Matt
Old Jan 25, 2002 | 03:27 PM
btt
Old Jan 29, 2002 | 03:53 PM
so now one knows??
92firebirdguy
Sep 1, 2016 07:53 AM
92-Formula
Dec 12, 2015 10:34 PM
L98GTA87
Oct 19, 2015 10:43 PM
jerflash
Sep 23, 2015 09:21 AM
BLK87Z
Sep 18, 2015 11:29 PM
