Crank No Start Help
Old Jun 2, 2024 | 10:49 PM
kaleleric's Avatar
Crank No Start Help
Hey all. I have a 1992 Firebird 305 5.0L. I have been having an issue with it cranking with no start. I have recently replaced the battery, starter, and distributor cap/rotor. After replacing the distributor last Sunday, 5/26/2024, it was starting and running fine. Now today, it is acting up again. Crank no start. Had trouble starting then finally cranked. As I was driving the engine cut out, power steering went out, and interior lights were on.
What else am I missing here? I’m growing increasingly frustrated. Any help is much appreciated.
Old Jun 3, 2024 | 10:14 AM
ironwill's Avatar
Car: 1986 IROC Z
Engine: 5.0 TPI
Axle/Gears: 3.23 Posi
Re: Crank No Start Help
Start with the basics; check fuel pressure, spark at the spark plugs, and signal at the injectors when the problem is apparent.
Old Jun 3, 2024 | 07:33 PM
Shoot starting fluid, or pour a bit of gasoline, down the throttle bores.
Try to start it.
Yes/no?
Yes: you have a fuel problem. No: ignition system. Given your list of replaced parts, I'd suspect the distributor at this point. Probably involves the pickup coil no longer supplying reference pulses to the ECM.
All that about PS "went out" is as useless as **** on a chicken. OF COURSE, when the engine quit, the PS "went out". Doesn't have much choice about that. Kinda like, the lamp in your living room "went out", when you pulled the plug outta the wall. What else could POSSIBLY have happened?
Abubaca
Apr 29, 2020 01:34 AM
walkthelin3
Sep 3, 2010 12:49 PM
Rich92 RS
Aug 3, 2008 09:10 PM
zrated57
Jul 18, 2007 09:30 AM
emmersonbigguns
South East Region
May 1, 2007 11:46 AM
