Do I have this cruise control routing correct?
Old Jun 6, 2024 | 09:43 PM
Nutro's Avatar
Trying to get this 92 Z28 a little more sorted out. I believe the AC compressor and system is full of frreon but have no verified YET. The compressor is not cycling on so I need to see if the cutoff switch is bad.
1. Does anyone know which relay on the firewall is the AC compressor relay?
2. Is this vacuum routing correct? I replaced the vacuum to the vacuum ball and now I get air through vents. I think this is correct anyway. Not sure if I need this fat one-way valve or this black/clear one at the intake or if it matters.
Old Jun 7, 2024 | 05:23 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Do I have this cruise control routing correct?
#1, your car does not have a relay for the A/C compressor clutch, that was a six cylinder car thing only.
#2, yes, your vacuum hose routing looks like it's supposed to.
As long as that new valve functions (one way) like the original, I see no reason why you couldn't use it
Old Jun 7, 2024 | 08:08 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
machine builder
Jul 19, 2022 05:11 PM
carbolicsoap
Oct 4, 2017 05:50 PM
Painmaster212
Aug 18, 2016 10:11 AM
bryanwood74
Apr 27, 2015 05:37 PM
nelapse
Jul 8, 2008 08:51 AM
