1986 Iroc oil pressure
Old Jun 24, 2024 | 05:09 PM
Shaunejulian's Avatar
Car: 1986 Blue Iroc Z TTop
Engine: 305 LG4
Transmission: 5speed
The oil pressure gauge has always worked. I recently changed my pcv valve and ever since my gauge will not work. If I tap on the instrument cluster the needle will jump around. Any ideas on what would be causing this? The engine is a 1986 lg4.
Old Jun 24, 2024 | 06:45 PM
Vader's Avatar
Re: 1986 Iroc oil pressure
Check the connector and wire at the oil pressure sender. For your '86, I believe that's at the rear ledge of the block, just to the left of the distributor,
Old Jun 25, 2024 | 08:43 PM
Engine: 305 LG4
I checked the wire. Everything seemed to be connected right. Should I try replacing the oil sending unit?
Old Jun 25, 2024 | 08:54 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Pull the wire off the sensor, touch it to a ground spot (bare metal on motor) and have someone watch the gauge for movement. If it does move the sensor is bad I'd guess.
8T7_I_ROC
Jul 23, 2023 03:23 PM
x91xCamarox
May 13, 2011 08:18 PM
drivera
Jan 3, 2007 12:29 AM
GCSIROC
Mar 18, 2002 02:06 AM
