Wonky Oil Pressure Gauge
Old Jul 23, 2023 | 10:59 AM
8T7_I_ROC's Avatar
Hi,
I'm in the process of buying an 87 IROC with the 305 engine and auto trans. Car has 141,000 KMs on it. The car is in great shape. Only issue I've noticed is that the oil pressure gauge seems wonky. Seems to stay really high, then drop off. The tach also seems wonky, and doesn't seem to show the correct RPM, but not as bad as the oil pressure gauge. Would this be an issue with the gauge cluster, or the oil sending unit, or something else.
Mike
Old Jul 23, 2023 | 11:10 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Wonky Oil Pressure Gauge
Might replace the oil pressure sensor or temporary install a aftermarket gauge to monitor. As for the tach look into Cajun tach shop replacement circuit board.
Old Jul 23, 2023 | 03:23 PM
Komet's Avatar
Car: 1989 IROC-Z
Engine: L98 350 TPI
I'd replace the oil pressure sensor first and see what that does. Sometimes the gauges will be a little sticky if it hasn't ran regularly for a while, otherwise it could be corroded terminals on the circuit board. If the circuit board is toast, replacements are available.
hedbob
Apr 11, 2010 03:38 AM
tesla421
Aug 23, 2009 06:34 PM
MP81
Dec 3, 2007 08:03 AM
warrior_91
May 1, 2003 11:34 PM
NOCANDO
Aug 26, 2001 04:34 PM
