Oil presure guage sticking
Old Apr 8, 2010 | 08:48 AM
hedbob's Avatar
Car: 1983 Camaro Z28
83 Z28 305 oil pressure gauge pegs out to the top of the gauge every time I start the car hot or cold. It stays there for about 10 minutes then go to normal operating pressure and works fine.
Can I just change the oil pressure gauge ? I have change the oil pressure sending unit. Also where can I get a gauge, the car is stock so I want to keep it that way.
Old Apr 8, 2010 | 01:43 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
That's pretty weird. Normally we'd say to replace the sending unit, but you've already done that.
Check the wire and make sure it isn't shorting to anything. Not likely, given the symptoms you describe, especially if it is consistent.
The only replacement you'll find is a used one.
Old Apr 9, 2010 | 07:50 AM
hedbob's Avatar
Re: Oil presure guage sticking
Can I just change the oil pressure gauge thats in with the tack or do I have to change the whole cluster?
Old Apr 11, 2010 | 03:38 AM
hedbob's Avatar
Can I just change the oil gauge which is in with the tack or do I need to change the whole cluster? Also any ideas where to finf a gauge?
Thanks for the help
junior419
Apr 7, 2025 11:35 AM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
tyeo098
Nov 30, 2015 06:27 PM
Ragtop Man
Sep 12, 2015 12:23 AM
andy74
Sep 3, 2015 08:41 AM
