Rattling noise after installing timing chain
Old Jul 7, 2024 | 01:30 AM
Coulter's Avatar
Hey yall, I recently installed a new timing chain with a new water pump as well, and went to start my car up for the first time today and it started fine and revved up fine with no noticeable issues, my problem is as soon as my car gets below 750 rpm’s a very loud rattling and clunking noise begins. It’s doesn’t seem to happen until I’m below 750 RPMS, sounds like the chain is slapping against something, but I’m not positive.I really don’t want to tear everything down again but I might have to. Anyone have any ideas why it could be?
Old Jul 7, 2024 | 06:32 AM
Vader's Avatar
Re: Rattling noise after installing timing chain
It would be easiest to check things that are most accessible.
Have you removed the belt(s) to determine if it's an accessory noise?
Is the harmonic balancer fully installed and running true? Are its outer ring and rubber isolator intact?
Old Jul 13, 2024 | 12:21 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
If it didn't make the noise before and it does now, Occam's razor suggests that something you reassembled is not quite right. Could be as simple as a loose belt, fan shroud, or misalignment of an accessory. Check over everything, use a straight edge on the pulleys, remove the belt and spin all the accessories by hand, use a mechanic's stethoscope to isolate the area of the noise and worst case start the project over.
Vassago
Apr 21, 2019 03:42 PM
Shredder1500
Jan 10, 2013 12:18 AM
cjames9001
Nov 28, 2008 01:15 PM
InfernalVortex
Jun 7, 2008 10:38 PM
rick89formula
Sep 27, 2007 07:50 PM
