Tach flickering when driving? Help needed
Car: 1986 iroc z
Engine: 305 tpi 5.0L v8 F Vin
Axle/Gears: Stock?
Hey all, first time poster long time browser here, I couldn't quite find the answers I'm searching for. When driving, my tach will flicker up and down and in wondering what the cause is. I think the transmission might be slipping because this does not happen when the car has been warmed up and driven for a bit. I'm planning to change the fluid out to see if it fixes the issue. Any help or guidance is greatly appreciated
1986 iroc-z
305tpi
700R4
1986 iroc-z
305tpi
700R4
Re: Tach flickering when driving? Help needed
1986 iroc-z
305tpi
700R4
1986 iroc-z
305tpi
700R4
That'd have to be one hell of a transmission slip to cause the tach to "flicker", surely you'd feel that as a hesitation while driving, yes?
I think doing regular maintenance is great and if you want to change your transmission fluid have at it, but as to your tach, I think I'd hook up one of those handheld "dwell/tach" units and see if the engine's RPMs are actually flickering, or if it's just a fault in your tach itself. The factory gauges in our cars are notoriously inaccurate and prone to several types of malfunctions.....
Car: check
Engine: check
Transmission: check
A flickering/jumpy tach is usually a fault in the secondary ignition systems. Plugs, cap, rotor coil and/or wires
RBob.
RBob.
